[SOLD] Looking for 17" diameter 7 blade mechanical cooling fan...non clutch
bbrroowwnn
never re member
Drums, PA
Anyone have a 7 blade regular mechanical fan...non clutch....that measures 17 inches in diameter for small block....if so message me with price and a pic...thanks
I need you to measure exact point tip to across point tip....go across the center hole to make sure you are at the widest point.........They both look like 18 inches at the widest possible point across.....I already have a 7 blade 18 inch diameter and the widest I can get my shroud on the radiator is 18-3/4 which is too close for comfort for me...It only gives me about 3/8 buffer on each side.......So I was wondering if they made a true 17" fan at the widest point.....Which would give me 7/8 buffer on each side.....I would feel much morte comfortable......
Maybe they didn't make one.....How about a 16" diameter non clutch 7 blade fan.....Anybody have one for sale???
Tip of a blade to the center of the hole.
All the blades are offset and they look like 17" but it's 9 to the center from any tip.
So it has to be an 18"
Yeah maybe due to the angle and pitch it is never really a true 18" across anywhere in its rotation....Could always take 1/4 inch of each blade tip but then you have to worry about getting an equal amount off and the balance of the fan...... 65dartman let me know what you got...
I have a true 17 inch diameter 7 blade mechanical fan. It measures 17 inches from tip to tip and measures 8 1/2 from center of the center hole to tip of blade. $25 plus shipping PM me e-mail for pics
