moper
After a busy summer of no car stuff... I have some time and the itch so I'm looking for the following stuff for my '65. I'm located in Columbia, CT 06237:
- '64-'65 A body floor shift power steering column and box
- '65 manual trans floor hump, bezel, and boot
- '65 manual pedal assembly, clutch pedal rod, Z-bar frame pivot, Z-bar, Z-bar to fork linkage/spring
- '75-up A/F body V-8 A-833OD bellhousing, cover, and fork
- Aluminum case A/F body A-833 transmission
- Dixco Mopar hood tach in working order.
I've got some stuff to trade, predominantly powertrain stuff: '65 273 long block (stuck), '65 273 4bbl intake and auto AFB carb, '65 V-8 904 transmission/convertor, '65 V-8 A body manifolds (complete with the lower brackets), std bore '70 340 block, 383 performance lower end - needs some attention, 383 bare block & crank, '76 400 shortblock (stuck), '87 360 4bbl - complete from truck, B727 auto transmission cores... If you're within driving range I'd also be willing to trade labor or cash - I can give references and pics for any work - rust/steel, paint, mechanicals, engines, whatever you need, from repairs to racing, stock to purpose built race - drag or road racing, with the exception of installing glass...lol. I can also pickup and trailer non-running vehicles. Let me know what you have and what you need.
Thanks
Thanks
