69413valiant
Looking for a 3500-4000 stall converter for my 440. What does everyone run these days? Not looking for tci or b&m
There are a lot of good converters. Dynamic, PTC, Coan, ATI, Ultimate, just to name a few. The last 2 converters I used were PTC and I have had good luck with them and the price wasn't too bad. Getting ready to install a new 904 with a 9-1/2 PTC spec'd to stall 3500 with my combo. Price was $500 to the door and they had it to me in 5 days.
Seems a lot of people like PTC after also searching old posts. Going to call them on Monday
You could put more converter in it if you wanted too.
Does the 3200 really stall 3200? I know that behind a 340-360 SB, the 10" hughes 3500 units I've had never stalled the advertised rate. Most were ~500 rpm low. The closest was a 10" behind a 408 and it was still tight about 200 rpm.
If you want something that will work better, have a custom unit built. Primarily 1/4 mile hits, have a tight 8" unit built. You'll be in close to $1K Even with the smallish camshaft a 4000+ stall will pick the car up as long as it's efficient up top.
IIRC, your car runs pretty strong for the build.
The top end at 1/4 mile is still pulling due to the 800cfm carb. Don't want the engine starving for fuel at 6000rpm.
I don't think my Hughes converter is stalling at 3200rpm. my guess it closer to 2800. At least that's what I feel.
The reason I asked is because I am pondering installing more cam.
If I had to do it all over again I would have stroked a 360 but I got the 340 from intake to pan for $200. It came out of a '70 Duster.
I like seeing A bodies running low to mid 11s at 120+. With the emphasis on plus.
Even if you got it to a true 3500, it would likely pick it up a bunch.
What's it run now for et/mph along with weight?
I forgot the heads you had on it or any work to them? If you have a dyno sheet showing peak tq and hp rpm levels that would help whoever built the converter.
Tracy, that's a screaming deal, for the technology involved.
I agree, that's a hell of a deal! If I was gonna run an off the shelf convertor (and I'm not), I would probably go with something like this convertor from Hughes. But at $536 I would go with the one Tracy mentioned above. I'm assuming that they took down all the info about his build and matched it to his intended usage?
