Looking for a Standard steering column
Marko
Vernon B.C
Rating - 0%
0   0   0
Hey Guys i'm in Dire need of a floor shift column for my 71 Demon that is with power steering...so needs to be like 38inch?? Let me know if anyone has one and willing to ship unless your in B.C Canada :)
Do you really need the whole column assembly or just the appropriate length center shaft? I have a whole column out of a '74 w/column auto shift. As long as your key is on the column and not in the dash the center shaft should work fine. If you can clarify where your 38 " measurement comes from I'll gladly measure mine (i.e. tip of threaded steering wheel nut stud to center line of coupler cross shaft hole) $40 plus shipping if interested.
Three on the tree with power steering is not a very common combination. You'll probably have to do what valiantpatrol suggests and that is to reuse your column and get a P/S shaft out of another. If your column is bad, you'll probably have to get two columns and make one good one out of them. According to Hollander, yours is a one year only column but I know individual parts are the same as other years. You may be able to use a '70-3 column with minor modifications. The '74-5 columns have more differences than the earlier ones but they might be able to be modified as well.
Good luck!
Marko
i have shafts and the top collar set up if you want to swap it all over. i am in salmon arm
If your looking for a floor shift column,dartman 440 has 1 with matching door locks & keys
SOrry guys i'm looking for Floor shift just realized it looks like i want column shift!!! CRAP lol totally went sideways on that one...Dartman 440 has this I need it lol!
yeah,he's converting back to column shift. Maybe you 2 can work something out. Say Chuck sent ya
