Looking for a torque converter.....
weaverjsnw
Medford, OR
Discovered a crack on the hub of mine...out of a 64 dart gt 225 w/push button a904. anybody know where I could find a good one?
Repair it how? Weld it and grind it down?
*pounces* You know the answer! :blob:
I did go there and found the one listed for my car. I haven't called them yet. Scared to hear the prices I guess. I don't have a lot of cash at the moment. Already borrowed $300 to do a basic rebuild on the engine. Just looking for options.....
thank you for the info...so far they are the only place I know....
I have one from the 904 trans we are not using. I'm in Seattle. I'll take pictures and we can talk after that.
if you have it repaired...make sure it is a chromemoly snout that is weld back on..
I have a rebuilt 904 torque convertor that I put only about 300 miles on. It currently is setup for a 360. Which means that the weight needs to be removed from the convertor and the slip ring on the torque convertor snout needs to be removed as well.
$75 + freight from Phoenix
Good luck,
Mike
call a local transmission shop-- not a national chain but one that has been there a while --you can still get this converter in stock configuration-- for not much coin. If you have issues pm me 7 i'll see if my local shop[ can still get it-- ,Lawrence
Awesome. I just got my engine parts in. Need to raise some cash. May take me a week or so. I'll get back to you when I have it. Thanks!
If you have a 64 engine and 904, isn't the convertor hub small compared to the 68 up convertors? The later convertors, large hub, will not work with a small crank register. Double check now before you put down your cash.
