WildCat
forgot a problem I had the last time I had it out on the road
3 years ago it would lock & unlock the converter at speed for no reason
I took it to have the trans serviced and he suggested a rebuild. 97K miles and no other problem but I wanted to up the power so i said OK and put in a good converter
Still would unlock converter so I thought throttle sensor. Changed that and it was OK till last Dec. On the way home from FL after driving 72 mph all day the last 240 miles home after fueling set cruise at 72 mph and just shortly after getting on the interstate the converter unlocked on flat ground. At 68 MPH it was fine.
Well, forgot all about it, I drive about 60 mph to and from work and really haven't driven it much other than that.
Yesterday on interstate cruise set at 73 mph for about 3 hours and then it happened, mainly flat ground, just the truck, converter unlocked.
Anyone else have a problem like this? So any thoughts? did the throttle sensor go bad again, maybe a bad ground, It is down to 64 mph to stay locked in, what a long day/drive
