Looking for leaf spring brackets
plymouthdude
butler,pa
Rating - 0%
0   0   0
Can anybody tell me where i might find the front and the rear leaf spring bracket that bolts to the body for a 1970 plymouth duster . I'm in butler pa.
I've got a whole complete set also so put me next in line. You can see the parts in the picture.
Ken
Edison, NJ
nice to know theres alot of help out there! :) another reason i like this place.
Just a little tip someone might like to know,...small block engine mounts from 80s ram pick-up are almost identical,shape,is the same,measures the same. Front spring eye location is the same, except smaller.Where it mounts to the frame reqiures drilling new holes, and welding in the threaded portion from the back side. Grind the welds down, drill the spring eye location hole to the right size & would take trained eye to tell the diff. Being engine mounts their mostly rust free. Idid`nt know this until i pulled 360 from an 80s pick-up.
