[WANTED] Looking for those stinking windage tray bolts
67Phish
Active Member
Dover, PA
Rating - 0%
0   0   0
Building a 360 right now. I have multiple windage trays but cannot find any of the bolts in my boxes. All that I really need is the main bolts. 340's or 360's are different, I know: but I'll do what I have to to make them work. I'm kind of at a standstill until I procure some. Photo attached for reference. Message me with pictures of what you've got and thanks in advance.
Don
I have used the studs in all small blocks with no problem
If you use studs you will have to have the block line honed with the caps torqued to the required value the studs are specify. Typically they require a higher torque value which can make the main caps slightly deform.
