Cool new avatar!And I can't say this for certain, but I bet the factory didn't mess with 3 angle valve jobs.
The son of Tim Ekstrand that won a couple of NHRA stock class National Championships with a 360 Duster with Bob Lambeck said Chrysler would send them 100's of stamped rocker arms. They would pick out the thickest ones and the ones that had the most ratio. Send the rest back for common replacement partsI have heard the old stocker guys would buy EVERY head they could get their hands on and start testing. Some were just better, some were horrible. IIRC, they ended up which a bunch of “crappy” heads in the end not knowing what to do with them.
Wonder what would make one of these castings “good”, and how that would be decided.Also, there are "good" castings that are sent to select racers. I've seen reference to that in the Chrysler interoffice memo's I have between Bob Tarozzi and Tom Hoover.
In all honesty, with a 2.02 valve job and 15 minutes with a grinder, the other 2 heads could have a way better port than the X head.
Since its in the casting can I assume that was equally true for non-X heads which came from the factory with 2.02 valves?When you start with a 1.88” valve head, then recut the seat to 2.02, then do the appropriate bowl cut, the short side becomes this tall, steep wall.
Whereas the X head has the SSR tapering down into the bowl, leaving much less of a wall.
My experience has been that it takes a fair amount of grinding on the SSR of the non-X heads with 2.02” installed valves to get to the as cast form of the X head.
It is.Since its in the casting can I assume that was equally true for non-X heads which came from the factory with 2.02 valves?
Interesting. Here's a picture of the SS on my X head. The 75 cut creates quite a cliff on this head as well. Probably not quite as big as a J or 587 cliff would be at 2.02, but still not a nice SS at all.Whereas the X head has the SSR tapering down into the bowl, leaving much less of a wall.
Same port as posts 14 & 27, now with the bowl machined with a 75* cutter, along with a typical basic bowl blend and some minor touch up of the SSR.
Nothing done to the rest of the port.
Lift——In
.100— 63.0
.200—127.7
.300—180.0
.400—224.4
.450—233.7
.500—235.6
.550—233.7
.600—226.2
I was watching Chris he said he also does a 90 degree cut to throat size, does doing that make sense to you? does seem like it would be a good way to go about it definitely simple, but also heard from Darin he don't make his throat perfectly round it biased to the ssr and center if I remember right.Interesting. Here's a picture of the SS on my X head. The 75 cut creates quite a cliff on this head as well. Probably not quite as big as a J or 587 cliff would be at 2.02, but still not a nice SS at all.
This is part of the reason I was hoping someone could share a picture of a factory valve job on an X head. I believe on my head the 75 bowl cut is factory. The 65/45/15 cuts are newer. The new cuts are concentric with each other, but not with the 75.
Sometimes there's a bottom cut , 75 or 90 i cant remember, I think 90 though.Can anyone post a picture of what they know is a factory valve job on an X head? I just picked up a set of 1967 production date heads that are in quite good shape, but I think they may have had 1 valve job. I have 4 angles on the intake and some non-concentricity. I believe the factory valve job would have been 3 angles, something like a 10-45-75. Pictures anyone?
Impressive exhaust flow huh? lolI have notes from a set of X heads I did several years ago.
First test is listed as “OE valves and OE valve job”
Lift——— I/E
.100— 54.6/48.5
.200—117.6/89.0
.300—170.4/117.1
.400—205.7/124.4
.450—216.9/128.1
.500—220.6/129.3
.550—220.6/130.5
.600—218.7/131.7
He sees the same numbers i get on mine.You must have a happy flow bench.
Sorry joke from another thread. I don’t think that’s out of the realm of possibility for a stock x head. Nor do I think the numbers from @Earlie A test are out of the realm of possibility. What is the margin of error on a flow bench in your opinion? Does the same head on a different day repeat fairly accurately?
X vs J, there's a notable difference indeed.Looking at the ports in those old heads it's amazing any of them were considered 'good'. They are all horrible by today's standards. Not really much difference between the X head port, the 915 J port or a 587 port. The X head intake port is about 5cc larger in the bowl and apex area and the 587 has the smog hump in the exhaust port. Other than that they are about the same. All are bad, some are worse.
The throat on my X head is 1.531/1.611/1.650/1.664 with width listed first, then depth parallel to intake flow direction, then two diagonals. 587 head is 1.531/1.572/1.591/1.566. There's a good bit more metal blocking the throat in a 1.88 valve head which validates your point about the short side 'cliff' being higher on the 1.88 heads.Granted this is far from having the two heads on the bench next to each other, but……..
If you look at the point where the bowl cut meets the SSR, you can see there is some of the tapering floor casting visible on the X head, but on the J head it’s a sharp edge.
Also, the bowl cut looks like it might actually be a larger diameter than the J head.
I’m basing that off the length of the 60* cut between the bottom of the 45 and the top of the 75.
The 60 is longer on the J head(and if you cut the 75 more, the cliff gets longer).
Also, keep in mind these two pics are of ports that are mirror images of each other.
Could be an effort reward type deal, get most of the rewards with minimal effort, not every customer is willing to pay for every last hp.I watched that video from Chad as well. I was very surprised that he said he used a 90 degree plunge cut to set his throat percentage. Very surprised.
As a matter of fact, I don't even believe he does it that way (all the time). Chad was trained by Darin if I'm not mistaken. And Darin has been teaching the offset throat in his seminars for years.
