Looking to buy the right steering column & coupler rebuild kit
Apples and oranges.
The first one is a coupler kit with the retaining clamp, and column bearing and isolator.
Second one is just the coupler kit.
First one should get you through the majority of a column rebuild, minus some small parts you may need from the hardware store.
line 8
"This fits all 67-73 A body, 66-73 B Body and 70-73 E Body that used the 3" long (overall length) power AND manual steering couplers."
This is what I have. Does anyone know how to take this apart? Thanks
Thanks I didn’t see how to take off the steering Coupler. I took the pin out but it’s still stuck. I soaked it with Liquid wrench because it was rusted.
I just went thru this on a seized one, ended up putting some thin pieces of wood on the steering box, and used a pneumatic air hammer with a pickle fork attachment to remove it.
I got the pneumatic pickle forks from Amazon.
Great I’ll try that. So there isn’t anything else holding it from coming off right? Other then the pin. Thanks
