GaryKephart
I need some input please. The steering in my 70 Dart has some play in it. Everything is new except torsion bars. Just back from the frontend shop. The mechanic noted the play and pointed a finger at the steering gear which is also new. He didn't adjust it. Should that need to be adjusted if brand new? I also noticed some vertical play in the idler arm at the pivot. I had my son work the steering quickly across the dead spot and could see the idler arm move up and down the bolt, that doesn't seem right to me. Should there be spacers on the top an bottom? Any thoughts?
Thanks
Gary
Thanks
Gary
