jacksdodges
jacksdodges
I keep losing water somewhere and its not leaking out. I start it up in the shop and it doesn't blow water and sut on my garage door which is about 2 feet from the tailpipe. I think if I had a leaking head gasket it would blow stuff on the door. It will lose about a 1/2 gallon per tank of gas 250 miles. I was going to pull the plugs and look at them but havnt yet. This is also strange I started it up and it was ideling for a minute and I check the headers to see how hot they were . They were all in the 600 range except # 8 it was 279 degree. It so happens #8 has a sleave in it which I don't think would matter. It doesn't run hot and has about 25000 miles on the motor. Its a stroked 340/418. This just started a couple month ago. I have not replaced the rad cap yet because it looks good and is fairly new. Going to do that when I get off here.
