Just got my car back from the shop. Brand new 318, supposedly broken in correctly. Ran good, test drive was good, then called and told me #7 cylinder was out and that it was acting like either a stuck valve or a flat cam. Told me that if it was stuck valve, the pushrod was likely bent and maybe no longer in place.
Called engine builder, he told me to pull valve cover and see if valves are moving up and down when engine is turned over. Pulled valve cover, pushrod had popped out (lifter still seems to be in place) but it's straight, not bent at least to eye and not enough to pop out. Valve looks like it's in closed position.
Could a flat cam or stuck valve could have caused this? Which is more likely? Anything else that could have caused it to happen? Has anyone else had this happen to them?
Thanks,
Ken
Thanks,
Ken
