inkjunkie
:read2:read the sticky about exploding torqueflights. just want to make sure i read it right, if the trans freewheels in low gear, low band is not applying and this is going to be a problem? so, if you were to use turbo actions valve body #17675 that states full engine braking you would be ok??
