hemi446
Here's my two cent worth first when you run that heavy weight oil it does take more HP to turn the oil pump I run straight 20w oil with a friction modifier (BG MOTOR OIL ADDITIVE) all the time on the track. The oil has too lube & cool the internal rotating parts but you are not running a long time but you are putting the max load on all the time. On the line size the bigger the oil gauge line the quicker the gauge reacts to the change in the throttle movement and if you have a problem it with show up right away if the gauge is at 80 PSI on the top end and now your down as little as 10 PSI you most likely have a problem. You may not hear it but you may have a vibration that wasn't there before. So it's time to check it out before the whole thing goes south and you have a bigger problem.
