jbc426
I had a low pressure issue with a mechanical pump years ago. The rod that is driven by the cam had worn down until it was too short to pump the pump. Swapped in a new one, and was back on the road.
Disconnect your fuel line at the carb and run it into a clean container. Have someone start the car and run it for a few seconds. You should get several cups of fuel at the least.
Be careful and prepare to fight a fire whenever you work on a fuel system.
