New build lots of used parts. 360+.030, J heads. fresh turned crank full grove main bearings. opened up oil passages.. solid cam .365 intake lobe .373 ex lobe using the old 273 type lifters{dumb bell shape}. so when its cold with 30w breakin oil I get 50psi at idle but as soon as it warms up to 200 deg I'm down to 10-15 psi. I am wondering if with this much lift in the cam if the lifters are letting the oil bleed by and that's why the pressure drops so bad when oil is warm.
