Lower Ball Joint bolt size?
Aaron
Fortuna, California
Does anyone know what size bolt and nut are used to attach the lower ball joint to the lower part of the spindle on a 1974 A-Body (Duster)? What grade bolt is recommended? I tore down the old suspension and am at the stage of installing the new lower ball-joints. The old bolts were rusted, and I had to cut the nut off most of them. Below is a picture of the old bolt (after wire brushing) and one new bolt I bought at the hardware store (as close as I could find to the old one). The new bolt is 5/8-18 Fine Thread Grade 8. Will this bolt work? If not, does anyone know where I can source the correct part? My service manual doesnt say what size bolt (that I could find).
Thank You
It should work fine as long as they are the same nominal size...I would use a minumum grade 8...alot of suspension bolts are grade 10...
