67barracuda
What the difference between the lower ball joint on a 65-72 abody vs 73-76 abody?
I'm in the process of a disk brake swap and my lower ball joint has a bolt pattern that is not wide or large enough for the spindles I installed. Could I have the wrong ball joint? I was told that this set up was from an abody 73-76. Should it have much larger bolts for the lower ball joint than the drum brakes I removed?
