My whole entire front end is brand new. There is a noticeable clunk in the front end just as i go into reverse and hit the brakes or put it in forward and hit the brakes. Only does it once each way. The only thing I could think of is there is maybe some play where the torsion bar goes in the control arm. I put the reinforcing plates but failed to clamp the control arm tight when I welded it. Your thoughts on where this click could be coming from? BTW everything was torqued and retorqued
