[WANTED] Lower Rear Shock Mount Plate
gzig5
Mequon, WI
This is for a 73 E body but I'm led to believe that A, B, and E bodies use the same part. I need a driver side shock mount plate for the rear axle. This is the lower plate the u-bolts go through and has the shaft to mount the shock. I've found that mine has been broken/hacked and the shock mount is missing. I can fix it but it would be easier if I can find one that is excess to someone's needs. I know they are available from various places, but I'm not willing to pay what the restoration houses are asking for a repop. The nut and shock washers would be an added bonus.
Shoot me a PM.
8 3/4" rear. I thought the plate was the same but U-bolts different for the smaller rear ends?
It's basically the same plate but the 8-3/4 plate is drilled for 3" c-t-c U-bolts. The smaller ones are either 2-1/2 or 2-3/4
I have 1 extra plate in the stash but not sure what side it's for. Will look tomorrow and answer back
I've pulled mine off (breaking off 3 of 4 u-bolt nuts of course) and am in the process of repairing it, so I don't need one anymore. But, there is another fellow on E-Bodies. com that was looking for the driver side as well as some other parts.
I have both sides still attached to a 70 cuda, I will look at them tonight and see if they are usable.
