Lowering front end
pressedham
Active Member
Ottawa Ontario
I am trying to get that lowered look.
Front end is higher than rear.
Is there a way to even the car out.
Will this affect caster/camber.
Theres a bolt under the lower control arms that will adjust ride hieght. Loosing it will let some pressure of the torsion bars and lower it. You could probably lower it a bit without worry to much about your alignment going out of wack.
That's the nice thing about Mopars - the torsion bars make it really easy to adjust the front end height.
i lowered the front end of my car by doing that. when you do it, loosen the bolt and take it for a spin of just lift the front end and push on it a bunch of times, or it will end up lower (trust me...). then, once you get it as low as you want it, tighten the bolt back about 2 full turns. the height on my car didnt really change much, and the lower control arms didnt smack on the frame anymore (that really bothered me) unless you have it pretty low (like mine ;) ) and you are hauling *** over a bump. but if you have new shocks on the front it wont be as bad as mine and my worn out shocks. gonna replace those soon anyway :)
ill get pics of how low it is on friday probably.
