[SOLD] Luniti Small Block Hydraulic Flat Tappet Cam & Lifters - New
Rocket
CT
For sale is a new Lunati hydraulic flat tappet cam part # 60404 and new Elgin hydraulic lifters. Cam specs are as follows:
Lift with 1.5 ratio rockers 513 Int 533 Exh
Advertised duration 276 degrees Int & 284 degrees Exh
Duration @0.050 lift 234 degrees Int & 242 degrees Exh
LSA 110 degrees
Cam and lifters are new. Cam is coated with a thin film of cam lube to prevent rusting.
Price is $220 plus shipping.
PM me with any questions
LSA 110 degrees
Pics?
Would this cam and lifters work in a stock 273, with a 2 barrel carb? I am interested if they would work. What else would I need? The rockers are adjustable.
This cam and lifter combo will fit and work with your adjustable lifters. Question is will this suit your overall engine combination and goals for the car. I will send you a PM later today.
You can get great advice by posting this question in the small block forum on this site rather than in this for sale add, and provide your overall vehicle combo (rear gear, trans type, …) and what your goal is with a cam upgrade and other changes you may be thinking of making. You will get good advice from members here.
Thak you.
