machining 273 crank for later 904 converter
The way to get accurate reading in a bore like that is with a bore attachment... It allows you to reach in the bore & have the indicator read without being at an odd angle..
Alright, just got the ID done,
At this shallower position, I got .006" max
This deeper one I got .002" max, more like .0015"
Both I'm estimating are 30 degrees from perpendicular so the actual runouts are higher than what I saw.
If I go deeper the gauge will be at 45 degrees and will probably deflect, but it's better the deeper I go so far.
The OD runout I'll get here soon, good call! Hadn't thought of that one
The OD will probably be "whatever" the factory spec is. I think the ID is ok. I don't think you'll have a problem with it.
I was trying to visualize something like that, thank you! Might also just play with some trig if I get bored.
Sweeet. Mucho appreciated. Why did that guy have to mess with my head lol
Thanks again guys!!!
