I've never retro-fitted EFI to an automobile. But I have worked on plenty of EFI machines.and
I don't know anything about the Fast system.
But If I had this problem,and the Fast system wouldn't run in Alpha-N mode, then I would be looking at ways to smooth the intake pulses, and/or averaging them out with a damper system,as seen by the MAP sensor.Essentially this is manipulating the signal that the sensor sees.This is like the vacuum damper in a vacuum gauge that is designed to be used on very short ram tubes on hi-rpm sportbikes.These bikes have notoriously low vacuum and it is pulsing wildly under the throttle blades until the rpm gets up around 4000rpm.So a regular,undamped Vacuum gauge will not work. Nor would a Map sensor. These usually run on Alpha-N if injected.
At one time I heard about a company that converted MAF sensors to output a MAP type signal. I don't particularly like MAF systems, but some very smart people continue to use them, to great success.
It seems to me with a TBI system, Alpha-N should work great, but of course,I have no idea what you are trying to achieve. But the idea of lowering the intake pad on a hi-rise single, to accommodate a stock hood would not be on my agenda.
You know; what I did see this one time, was a remote MAP sensor with about 4 feet of small diameter tubing leading up to it. I bet that tubing damped the pulses pretty good! As to it's response time I cannot say......
Perhaps an inline plastic pulse damper.....
IDK
