Magnum 360 Budget Rebuild Advice
So are you guys are suggesting, that as long as there is no ridge and the factory crosshatching is present there is no need to hone the cylinders?
I would say that, yes. You want budget, right? I'd remove one rod and one main cap and inspect the bearings. If they look good, run the short block as is.
I think key word is budget here budget to me means no machine work or very minimal. I did a 340 up and i sent the crank out cause it needed it honed and re ringed a standard bore block and had the heads rebuilt it wasnt cheap but its a 340 prob a couple grand anyway just to overhaul it not including core price. I had the engine laying around.
