Magnum engine swap
Eric Pearson
73purpule duster
Houston Texas
Good evening everyone. I’m looking for some advice on what someone is using for the hose that goes from a eldelbrock air gap manifold to the large port on a LA style water pump. The outlet on the air gap manifold is straight whereas the other manifold has one that is angled. Thanks for the help
I took my LA hose to the parts store along with my digital calibers (Magnum is larger on the intake side) and asked if I could go back to find one. Took me 3 trips to find one that works. Sure hope it lasts cause I didn't write the number down!
Edit: it's slight creased on the bend, but not bad.
Heres the stock mopar 340 bi-pass hose I used.
Enlarge pic for part #.
Cheers!
