Magnum Heads on LA Block - Oil Holes
74desertduster
Tucson AZ
I have assembled and closed up the bottom end on my 360 build. Now am focusing on the heads and intake.
I did not drill and tap the LA block to head oil holes for plugs and am wondering about plugging them somehow.
I can't use anything that will cut now....yeah, I know...plan ahead.
Is it even a concern?
Thanks!
I used no sealant or plugs in the oiling holes on my 77 360 with magnum heads. I have over 700 miles on it so far and I've had no issues.
Same here just put gasket and heads on, 3500 miles no problems.
I have almost 30,000 miles on my LA/magnum hybred and didn't do anything to plug the holes. No leaks or oil pressure problems. I would say it' not a concern.
