fishy68
Tyr Fryr's Inc.
Fishy is right. The motor provides vacuum for the booster. One question I did come up with tho, will I need to change my manual steering, or do I try to bypass the PS pump with a NON PS setup?
j
The new pump probably won't work since it's for rack and pinion. I can't remember the diff. but I remember reading they are different. If you can adapt the old style pump to bolt to the magnum engine and use the serpentine pulley it should work ok. Might be a challenge doing that though. You might contact one of the steering companies and see if they could give you a a better idea of how to do it.
