T56MaxTorq
Putting a different oem mag crank (10/10) in my turbo 318 with arp studs (never line bored for studs) and started taking some measurements. Plastigauge and a mic. Plastigauged all 5 by putting it in 4 places, 2 on the bottom and 2 on the cap, 90* apart, 45* off bearing half split line. All is well there, .001-.0015 on all. Grabbed my mic and read .003. The split line is .0055. I know the split line is eccentric but is this too much?? I don't have a fancy dial bore gauge so I used the regular type and found it difficult to use and set. So I set the mic to XYZ and locked the bore gauge on this measurement, basically using the bore gauge as a go-no go. Mic is excellent quality and recently callibrated. I've only measured #1 so far.
Wanting to cover all bases on this as I had a bad bearing on the old crank and this new one is not the original. Plus I added the studs. I plan on only street use, maybe a 1/4 mile or two. 15w40 or 20w50 synthetic oil. Basic oil pump with oil mods - smoothed out #5 cap and oil filter mount ports, opened up the pump intake and put in a bigger homemade pickup. Have a roller cam so no top end or cam oiling mods.
Will also check crank out of round, freedom of movement, and end play. Is there anything else I could be missing?
