Trial and error.
They say altering the spring packages changes how the car will launch, corner, and ride. I agree with all that.. . . To an extent. Sure, adding a leaf makes for a stiffer ride, but it may help as well with a corning car. Drag wise, a stiffer spring may help with squat off the starting line. It seems Chrysler spring do things in the opposite direction of what convential wisdom dictates, and I mean it in a caring way. Instead of leaving the starting line with the back end buried, MOPARS lift and GO!
Experimenting with Chrysler spring packs, mixing and matching, may yield some terrific results, or absolutely nothing. They spent alot of time and money in the 60's playing with all sorts of combinations. I think the problem with todays springs is a result of alloys of steel that do not match up to yesteryears. I've heard the old 'wive's tales' about how old Super Stock springs are better than a new set of springs. I"d like to test that theory, as I check Bob Moshers(wwwmoparsbymosher.com)trash dumster on a regular basis looking for old springs!=P~
