Manley Pushrods 25339-8
Are these pushrods soild??? or oil trough type?
25339-8
Shop High Performance Push Rod 25339-8 From Manley Today
I have a Small block LA type, with through the shaft oiling system
You know that’s for 8 right. If I’m going to spend that much money I’m getting custom pushrods. Also on many of these heads 3/8 pushrods will require clearancing. Especially if you start playing around with rocker ratios
25339-8
Pushrod Series – Manton Pushrods
techline@mantonpushrods.com
Just for a reference, Manton sells an 11/32" x .120" wall 3 Series (or a much stronger 5 series 11/32"). I was just quoted $264 for complete set of the 3's. That price includes three different lengths that I wanted. They sell them with the holes, so just tell them what you need.
Yes I am aware that's for 8. I am running the Indy 360-2 heads and indeed we are doing some clearance work....
Are they solid ? or oil through type?
Based on the pic in the catalog, showing a cutaway of all the pushrods in that series, they’re oil thru.
For non-oiling pushrods like that, you’re more than likely going to need something from Smith Bros, Manton, or Trend.
The only way you will know for sure is by taking five minutes and giving them a call. We all could take a guess but I’ve been wrong before once or twice. Lol
Price looks like it will be the same anyway. He will probably need two different lengths with those offset rockers anyway.
