Manual or auto choke Hi-po 65 Dart?
Stumpy
WA
The new Dart I bought today has a frozen manual choke. The car is a numbers matching hi-compression 273, 4bbl, 4 speed that is basically a 65 Dart Charger without the yellow paint and badging. It is not the original carb.
Does anyone if manual chokes were standard on the hi po 273 in these?
Thanks. It came with a stock carb, but it is reconditioned garbage. Any suggestions to track down a stock carb body I can rebuild properly?
There are application listing of Carter carb numbers on the web. That number posted in Parts Wanted might get you a good rebuildable core.
