I converted by 1974 4-Speed Duster from Manual Steering to Power Steering. As you all know the steering shaft is to long.
So drilled out the plastic pins that hold the two pieces together. Well the issue is the lower column bearing I have is not the plastic one with the two bolts. The is a retainer welded to the shaft than a spring and is appears the bearing is pressed on.
For the shaft to collapse the way I want it to I need to remove the reatiner, spring and bearing and slide it down towards the steering pot coupler. Can I just replace it with one of the plastic lower column bearings with the two bolts?
Attached is the picture of the current bearing.
