[FOR SALE] manual valve body
mikeg1955
goodlittsville tn
Rating - 0%
0   0   0
Cheetah reverse manual valve body and deep tran pan filter extension and pan gasket went to a tran brake valve body valve body cost 250.00 by itself sale my for 200.00 + shipping 750 dp holley carb was rebuilt back in the summer 250.00 + shipping pm me at [Email removed by staff]
Can you make it a forward - manual valve body ? you need a reverse shifter with that , correct ?
I didnt reverse my column shift when. Installing mine which is same as this post..just shift down each gear until it stops
would that work with a B M floor shift ?
I am looking to go a manual valve body , but already have the shifter.
I am not qualified to accurately answer that, but I don't see why it wouldn't work fine. Your numbering on the shifter itself will be wrong. Whether up or down shifting manually 1, 2, D or vice versa, I don't see any difference myself. Suppose you could contact B&M or Summit/Jegs, etc and see. All I know is my factory column shift works fine, just ignore the idicator.
