Manual Valve Body
bigdemo1
Why do so many people run reverse valve bodies?are they better?can someone explain please.
Reverse is the way the pattern sets up after it is modded. And what is good about it is that you start off in LOW right, well as you hammer the shifter back 1 at a time you go to the next gears right, 2nd, then 3rd. And you dont risk Reverse and or hitting Netural like in a standard pattern.
O.K. just always wandered why nobody ran forward pattern.
