master cilinder choice 68 valiant
TheDeputy
I'm looking for a new master cilinder for my 68 valiant 2dr sedan. I want to keep it stock looking so it has to be a cast iron one. The valiant has manual brakes with 9" drums all around.
Is this the right one, or do I need something else.
RAYBESTOS Part # MC36221
{Professional Grade Bore Size=1" Number of Ports=2 Primary Outlet Size=9/16x20 Secondary Outlet Size=1/2x20}
Front Drum Brakes
getimage.php
it looks right, non of them are going to look correct to someone who knows what a oem original one looks like.
68 master with drums all around had a small master cylinder with 2 equal size resivoirs and a bolt in center holding the cover on.
Do you mean this one.
DORMAN Part # M71258
{First Stop #2808577, 2808599, 5472965}
w/Manual or Power Drum Brakes; Bore = 1"
getimage.php
Which of these two would be the better choice. Will it fit my original pushrod, or might that be too short.
Thanks,
Antoon
