I just purchased and installed a brand new, not rebuilt, master cylinder from NAPA. I bench bled it and installed it on the car. I bled the brakes. There is no more air coming out of the bleeder screws, just clear fluid. The pedal goes to the floor. If you pump the pedal, it comes up. Then if you release the pedal, it goes right to the floor if you push it again. Is this new master cylinder shot?
