72greenswing
New Member
Hi guys I’m new here and new to mopar in general, I am running brake lines and can’t directly find an answer or the right pic. Can someone provide info or a pic of the front and rear brake lines that go from the master cylinder to the proportioning valve or known as distribution valve I know one goes to the top of p valve and one goes towards the front on the bottom of p valve it is a drum/drum set up so the size of the master cylinder is the same as I’m not sure which port is for front brakes. Thanks
