Master cylinder to distribution block drum/drum
72greenswing
New Member
ohio
Hi guys I’m new here and new to mopar in general, I am running brake lines and can’t directly find an answer or the right pic. Can someone provide info or a pic of the front and rear brake lines that go from the master cylinder to the proportioning valve or known as distribution valve I know one goes to the top of p valve and one goes towards the front on the bottom of p valve it is a drum/drum set up so the size of the master cylinder is the same as I’m not sure which port is for front brakes. Thanks
I have this pic I copied. Disc/drum but I think its the same. I'm assuming a 72 Dart?
Yes sir sorry 72 dodge dart swinger and that is a great pic thank you as far as the master cylinder side goes the brake line closest to the fire wall is for the front brakes and the other rears correct? Mine is so rusty you can’t really read the letters at the ports
