Match Race ~ 1968 Barracuda '383-S' vs. 1968 AMX '390'
don`t know the answer to this one, but I had a brand new 68 form. S fastback. the book said it was a road runner engine, w/ a pinched down exh. manifold on the drvers side. the tires back then weren`t to great, the fish wouldn`t touch the ground when I got on it, like it was on ice! big fun for a 22 yr.old!
Shipping Weights and Engine Ratings
________________________________________________
1968 ~ Barracuda '383-S' Fastback.............. #3249 lbs.
* 300 HP @ 4200 RPM's
* 400 Ft/Lbs. of Torque @ 2400 RPM's
Note; The 383 Engine in the 1968 Barracuda '383-S' did 'not' have the same Valve Train {Camshaft or Valve Springs}
as the 1968 383 Road Runner Engine.
Note; And yes, the Exhaust System was 'completely squashed' restricting exhaust flow.
1968 ~ AMX '390'......................................... #3132 lbs.
* 315 HP @ 4600 RPM's
* 425 Ft/Lbs. of Torque @ 3200 RPM's
Lighter car with more motor- AMX
If it hooks better.
If it hooks better.
Tires > Both came thru with E70 x 14" {Baloney Skins > 6.25" Width x 26" Diameter}
Front-to-Rear Weight Distribution;
Barracuda '383-S'
Front...... #1845 lbs. {57%}
Rear...... #1404 lbs. {43%}
Total...... #3249 lbs.
AMX '390'
Front...... #1627 lbs. {52%}
Rear....... #1505 lbs. {48%}
Total....... #3132 lbs.
Transmission Comparison
Mopar A-833
Ratio's ....... 2.66 / 1.91 / 1.39 / 1.00
Borg-Warner T-10-V ~ 'Close-Ratio'
Ratio's ....... 2.23 / 1.76 / 1.35 / 1.00
Franco-American
Exhaust Systems
AMX > {Full Body Exhaust System}
* Exhaust Header Manifold {Log-Type}
* 2" Exhaust Header Manifold Outlet
* 2" Front Pipe
* 2" Intermediate Pipe
* 2" Muffler Inlet
* 2" Muffler Outlet
* 2" Tail Pipe
While the Exhaust Manifolds were considered 'fair' at best for Exhaust-Flow, the rest of the
Exhaust Pipe System was regarded as pretty good.
Chick,
Camshaft vs. Camshaft
______1968 Barracuda 383/300 HP____ 1968 AMX 390/315 HP
Lift.............. .425"/.437" ........................... .425"/.425"
Duration...... 256*/260* ............................. 266*/266*
Overlap.......... 32* ......................................... 44*
LSA................ 112* .......................................112*
Valve Springs________________________________________
Closed...... #108 lbs. @ 1.86" ..................... #86 lbs. @ 1.81"
Open........ #234 lbs. @ 1.40" .................... #193 lbs. @ 1.40"
1968,
In NHRA 'Pure' Stock Class.
* 1968 Barracuda '383-S' {383/300 HP} ....... F/Stock {10.50 to 10.99 Wt/Hp}
* 1968 AMX '390' {390/315 HP} ................... E/Stock {10.00 to 10.49 Wt/Hp}
* Magazine Recorded Performance
AMX ~ 4-Speed ~ 3.91 Gears ~ E70 x 14" Tires
* 14.19 @ 99.14 MPH
* 14.21 @ 98.50 MPH
* 14.30 @ 99.00 MPH
* 14.31 @ 98.86 MPH
* 14.33 @ 97.15 MPH
