Match Race ~ 1968 Road Runner '383' vs. 1966 Mercury Cyclone GT '390'
Stock vs. Stock
* 727 TorqueFlite ~ 3.55 Gears 'Sure-Grip' ~ F70 x 14"
vs.
1966 Comet Cyclone GT '390'
* C-6 Automatic ~ 3.50 Gears 'Limited-Slip' ~ 7.75 x 14"
An 'fairly even' race off the line, with the Road Runner gaining a
1/2-Car length slight-edge lead.
The Cyclone would stay close to the Road Runner thru 1st-Gear as both pull to 4800 RPM's.
The Cyclone would hit 2nd-Gear at 4800 RPM's while the Road Runner could pull up over 5000 RPM's.
The Road Runner would start to edge away from the Cyclone thru 2nd-Gear.
The Cyclone would hit 3rd-Gear first at 4600 RPM's, as it would be
1-Car length behind.
As the Road Runner peaks at the end of 2nd-Gear, the Mopar would maintain it's slight lead.
The Road Runner bangs 3rd-Gear at 4800 RPM's, and now pulls away from the Cyclone as the 390's Valves start to float out on the big end.
The Road Runner opens up a near 2-Car length lead and hits the Traps at 94.7 MPH with a 14.86 Elapsed Time.
The Cyclone 'lags' 2-Cars behind, and hits the traps at 92.5 MPH and with an ET of 15.05
Me being a relic from that era I can only tell you from memory that driving a new 1970 Swinger 340 dead stock, neither of those vehicles were a problem to the Dart.
You got that right spanked many big blocks with a 340 duster:D:D:D
Frank-n-Beans
Stock vs. Stock
The Road Runner came thru with Goodyear 'Red Line' F-70 x 14" Tires
* Diameter ... 26.45"
* Width ......... 6.55"
The Comet Cyclone GT 390 came thru with Firestone '500' 7.75 x 14" Tires
* Diameter ... 27.02"
* Width ......... 4.50"
This ain't helping the Comet Cyclone off the line.
If I wasn't a died-in-the-wool Mopar guy I'd probably have a big Ford wedge with Kaase
cylinder heads.......Something I never would have said in years past. But Chevy? Never!
If you want an "FE lookin" killer for not terribly huge coin, go to the boneyard and
find a 460. Get a set of Jon Kaase's P-51 cylinder heads and a SCAT rotating assembly
for up to 545 cu in.
They even took a stock stroke 0.30" 460 with prepped stock rods and made a staggering
690 hp at 6,700 rpm with 600 lb-ft of torque.
http://www.jonkaaseracingengines.co...e-products/188-kaase-p-51-cylinder-heads.html
Here's a complete P-51 engine from Kaase that makes 800 hp and 740 lb ft torque!
http://www.jonkaaseracingengines.com/component/content/article/211-520-ci-kaase-p-51-engine.html
Larry,
1968 Road Runner 383
The 727-B Torqueflite > 2.45 ~ 1.45 ~ 1.00
Torque Converter > 10 3/4"
Stall rate was rated @ 2100 to 2300 RPM's
1966 Cyclone GT 390
The C-6 Merc-O-Matic > 2.46 ~ 1.46 ~ 1.00
Torque Converter > 12 5/16"
Stall Rate was rated @ 1660 to 1800 RPM's.
Gene
These '2' cars were in the same NHRA Class at the end of 1967.
1968 Road Runner 383 = 10.22 Wt/HP
1966 Cyclone GT 390 = 9.89 Wt/HP
B/Stock = 9.50 to 10.59 Wt/HP
When the 1968 Road Runners were introduced in September 1967, they
were classed in B/Stock.
In 1968, the NHRA changed the Stock Class factors;
* D/Stock ....... 9.50 to 9.99 Wt/HP
* E/Stock ....... 10.00 to 10.49 Wt/HP
Gene
69 Cuda 440: Did you ever build one (a street /strip 390,properly done...), for a customer? (Just curious on your mods,did one a few years back.)
A-Body-Bomber
Yes, we built more than a few 390 HP Engines back-in-the-day for customers.
Either for 'NHRA Stock Class', or high-performance 'Street Machines'.
390 'FE' Short Block
I know that we always used the Cast Crankshaft {63 lbs.} because it was lighter than the Forged Steel Unit {76 lbs.}
The Cast Crack was never a problem, as long as the internals were balanced.
The 390 needed to get higher RPM's to perform.
Biggest problem for the 'Stockers', was the heavy Connecting-Rods and Pistons preventing the 390 to reach attainable RPM's for power.
If I remember correctly, we used the 'early' C3AE-C Connecting Rods
with 3/8" Bolts. They were the lightest Rods, and came in at around 760 Grams.
We heat-treated them first for improved strength, and then
'shot-peened' them for added stress-relief.
For the Street Performance cars, we used 'Speed-Pro' Forged Pistons, and lightened them up.
For the 'Stocker' Race Engines, it was 'Arias Pistons'.
If I wasn't a diehard broke guy all the time, I'de have me a SuperFlow dyno in my garage!!!
Great thread, 69 Cuda 440!
Ditch that 390 anchor and drop in a 351C-4v...4.11 rear and hold on!
Easy there 'Pishta'
Back in 1966, a set-up Mercury Cyclone GT 390 could run near
'dead-nuts' on 13.00's in C/Stock.
They were very competitive in C/S and C/SA back then.
There were some people running 390's in circle track racing locally with some success in the 60's and early 70's but for the most part the big-block Chevy's were the first choice.
Front-to-Rear Weight Transfer[/I
............................. Shipping Weight .... Front .................. Rear
______________________________________________________
68' Road Runner '383' {3424 lbs.} . 1814 lbs. {52.0%} .. 1610 lbs. {48.0%}
66' Cyclone GT '390' {3315 lbs.} ... 1875 lbs. {56.4%} ... 1440 lbs. {43.6%}
Note; The 1966 Cyclone GT '390' came thru with a fiberglass-hood
with non-functional vent scoops.
Note; A 'standard' steel hood weighed in at 67 lbs. The fiberglass-hood weighed in at 33 lbs.
Easy there 'Pishta'
My Ford buddy in high school had his dads old Cyclone GT 390. Motor was on its last legs so we pulled it and put a 302, then a Cleveland with 2bbl heads and a 4bbl intake. Erson Hi-flow 2 cam and it ran like a scalded dog. He had that car for years and finally found a set of 4v heads. Stroked the 351 to 392 and installed EFI and it was even faster. Sold the motor last year in a 67 Mustang after 28 years. I enjoy these posts.
1966 Mercury Cyclone GT 390
Cylinder Heads
* Style .......................... Low-Riser
* Casting # ................... C6AE-R
* Intake Port Size .......... 2.34" x 1.34"
* Exhaust Port Size ........ 1.84" x 1.28"
* Combustion Chamber ... 63.60 {Minimum}
* Combustion Chamber ... 67.0 to 70.0 {Factory}
* Intake Valve ............... 2.037"
* Exhaust Valve ............. 1.560"
* Valve Spring {Closed} . #95 lbs.
* Valve Spring {Open} ... #255 lbs.
* Generally good flowing 'street performance' Cylinder Heads.
* Some restriction thru the Exhaust Ports.
