DaveBonds
Garage Trash
Coil clearances aside, what is the highest total lift that can be had on a factory, uncut LA head valve guide with a stock seal?
Thanks, Bruce. That's what I'm reading and measuring loosely, with crude measuring tools. My mic's are at work! hahaha...
I don't think I'm going to freak out over cutting these guides. Especially on a set of used 1.5 rockers. I'm on a .489 exhaust lift, so I think I'll be ok.
not to hyjack but I plan on putting a .507/.510 cam in my 340 with X heads. I have'nt measured anything yet but I'm wondering if i'm gonna have to do some extra machine work.
Dave,have personally seen a .480/.494 hyd,clear a stock valveguide.Using 340 replacement springs.
x2 always check...**** happens faster than it takes time to checkstock rockers...are not 1.5...probably close to 1.4...and you are going to lose another .010 lift due to the back pushrod angle in sb mopar..but if it was my engine I would check the clearance before I started the engine....
.............I have ran the comp 525 lift hydraulic cam with uncut guides...............kim........
The ramp speed of thier camshafts that have that shorter total lift may require heavier springs and thus require guide work.
That's why I was curious. Maybe it depends on the head? Maybe not even the number, but actually the particular head. Hughes calls caution on anything above .450" on their website, but on other pages of their site, reference .500"
The heads that I'm checking are a 302 and seem to have somewhere just over .500"
I have a few different vintage heads that I'd like to check and see where it makes any difference.
I bent all 16 pushrods due to coil bind on a 79 360. The cam lift was 480 advertized with 1.5 rockers.
No - I meant issues with coil bind as opposed to retainer to guide - sorry if I confused.
You might have an issue with the 360s exhaust valves - they may have the lock groove lower than the intakes if the engine had the rotators on the exh valves. I know the 901-16s on my truck have a slightly heavier seat presssure than the intakes becasue of that. I removed the rotators but the lower groove remains. It's no issue - the cam is small - but it's something to watch for if you're not replacing the valves.
