If only it worked that way (all the time). Here's a before and after correction. With 'correction' the rocker ratio went down, lift went down, valve speed went down. This is one example. I'm not making a blanket statement.
I think you’ve posted these numbers before.
You are correct that your numbers show them almost equal off the seat and the corrected numbers start slowing down sooner. But it still looks like around max lift the corrected numbers are slower.
When we get down to the nut cutting the corrected geometry will always produce smoother valve train operation and the engine will rpm higher with the same or even less spring load.
To me, that aspect is far more critical than leaving the geometry uncorrected and having the valve train in distress.
I see a ton, far too much valve train distress on the dyno. Not just Chrysler stuff either.
