Originalowner73 340duster
I'm converting to two prong ballist with my new system . I got.new distributor harness and module.coil and ballist.. question is I got the keypower on side but the key on start power side was never on my car on prong ballist???. Can I just hook up as is or should I run a jumper to the yellow key power on at relay..and then if I do run the jumper to the relay from other side of ballist which goes to/from positive side coil won't it run power back threw the yellow wire and activate starter??
