MDS Questions....?
MonkeyMadness
Yorba Linda California
Hello,
I have an 06 Non-eagle 5.7 My harness and ECU (Bouchillon Performance) have the MDS delete. I don't plan on removing the heads anytime soon. So swapping the lifter is out for a while.
Question.
1. Will leaving the MDS lifter effect anything or do I need to swap them if I'm not running MDS?
2. Can I remove the solenoids and replace them with plugs will this effect anything or should i leave them in if the lifter stay for now?
3. Has anyone had any issues with the MDS?
Any and all comments or info is welcome.
Thanks
j
Leave it as is. Do not remove solenoids without also doing lifters. I f you put in the plugs without doing lifters, they won't pump up. Thus giving you a 4 cylinder full time. Just leaving it alone, it will function as normal.
Leave all of it alone, for now. But eventually you will want to ditch all of it. The MDS is known for causing problems if you’re not using it.
