Should I make the swap to G3?
Anything besides the power difference between the two that makes the G3 the winner for you? Did the swap result in no oil leaks like you hoped? Do you see a difference in drivability?
I understand about the idea of more weight and not wanting it. I want to put a HC blower on my 5.7 but every time I see someone mess with one and use an engine hoist or two guys and a spreader bar and chain to remove or place it, I think to myself "do I really want one?".
Plenty of reasons to love a G3. Zero oil leaks. The engine is just as clean as it was the day I installed it. Now if I could just get the damn TKO500 to stop the occasional drip. The G3 just seems happier and smoother cruising at 70-80mph. The camshaft turns on around 3000 RPM and it revs incredibility fast. Now more practical info. I live in the south, it gets stupid hot here. When the LA would get over 205, it seemed to be hating life. Noticeably down on power and sluggish. I've had the hemi running at 215 sitting in traffic with the AC on and it ran just like it did when it was 180 degrees. I just think they handle heat better than an engine that was designed 60 years ago. Oh, v-belts suck.
One bad thing about the hemi, most of the stock intake manifolds are flat out ugly. The 6.1 is by far the best looking stock intake available, but I kinda like the idea of a plastic intake to keep the intake temperature down. I knocked the ugly off of mine by sanding all the casting marks and other random ugly crap off of it. I think I accomplished knocking the ugly off of it. Note, these are 6.1 hemi coil covers that I "erased" the 6.1 callout.
I think part of it for me is also just that my engine bay is kind of rough to start with. I did try to rattle can it back to somewhat the same color as the body when I first put the engine in (I have the pictures to prove it used to look decent, lol), but I didn't do any kind of metal work or anything to smooth things out. I think one of my fenders used to be blue, the other green, and the rest of the car gold based on what shows up under the paint flakes. I also just seem to have a lot more stuff mounted on my fenders, but a lot of that is because I didn't use a factory PCM I guess.
I think a big part of the engine bay cleanliness is the idea of keeping everything you can out of it. But I think that idea as a whole is fairly labor and fabrication intensive. Hard to hide an AC filter/dryer under the inner fender without all kinds of extra work as an example.
I just hope mine looks at least well thought out as I doubt it will look clean. I am going to keep the PCM in the engine bay in about the same spot as the OEM location, plus I will have a PDM, AC dryer/filter (at some point) and probably a coolant reservoir. I could see it getting pretty busy. The only thing I have going for me is the battery will be in the trunk.
The goal when I built it was to have the firewall and fender wells completely clean of everything. It certainly adds complexity and thought to make it work. Pictures above are right after I installed it. Since I’ve ditched the corvette regulator and have a normal return style. It pained me to mount it on the fender well. It fairly low and black so it’s not really noticeable. My problem is I put appearance before simplicity. It’s sometimes comes back to bite me.
Thanks for sharing your guys updates on this thread. The swaps look really clean. Good to see some old school meeting new school tech.
I don't know if it will ever be done. LOL. My wife wants me to fill the holes on the side of the Dart. I think it looks fine. As for cost, don't ask! :rofl: Oil leaks? Nope. I had one in the back of the oil pan by the rear main seal. It was due to poor workmanship on the oil pan. The groove for the o-ring was too deep. All I can say is it's not leaking now and the fix gasket maker. My car now has AC, 3.73 gears, 6 speed, and a 6.4. Dynoed 470 to the tires with the out door temps at 100 degrees. Fuel mileage driving to and from the dyno was about 18 MPG doing 70-80 with the AC on. Wiring any car takes time and patience. My car is using the Holley Terminator X Max with the wiring harness. One thing to double check before you pull the old engine is the pinion angle if you are swapping the rear end. Mine was off by 4 degrees. Sounded horrible at 70. I think the next mod is to replace the windshield and add a power port for my phone and a place to hold it.
I've been following your build on FB, didn't realize you were on here too. Love the build!
I leaded my holes. I tapered the holes and use adhesive style foil on the back. Leading requires much less heat so less distortion. It's been almost 10 years now with zero issues.
I will also be running the terminator, what was the wiring up of it like with the harness they provide? Is it all pretty much plug and play?
Any issues i need to look out for and are you running fly by wire throttle or mechanical ?
