Metal spray to repair cast parts.
Dana67Dart
The parts you don't add don't cause you no trouble
Northern Colorado
Very interesting
Wonder if it would work in floors where there are small pinholes or even larger holes?
The material for a foot would cost you more than a complete floor.
My son does spray welding on engine blocks . Its $300 to $400 for a couple of oz's just for the iron material. It does not go far.
Spray welding is the most expensive welding for material use. These types of repairs are for restorers with very deep pockets that cannot find very expensive parts. Also you cannot weld onto rust with any type of welding. You will just blow a rusted floor away.
You would be better off using JB weld after blasting it to bare metal
I’m not sure if there any still out there but there were companies that sprayed a galvanized material to repair floorpans and other rusted body panels.
