Mild 360 vs Mild 365, new member
Colby Ford
New Member
Alexander City, AL
I have mildly built 360 in my 76 duster right now, makes 229 hp and 298 tq to the wheels. Engine has stock bottom end, comp extreme energy cam, double roller timing chain, stock "302" heads, edelbrock rpm airgap intake, 2 inch carb spacer, 750 holley double pumper. This setup runs 13.80s with a 2.76 rear gear with a stock stall. I have a 360 bored .030 over with stock crank, flat tops, custom grind cam 440 lift, double roller timing chain, magnum heads, mopar performance intake, 2 inch carb spacer, 750 holley double pumper that i plan on putting the car. I was wondering the times and power numbers yall think it'll do. Thanks for any response.
Not enough info on the second engine. More detail please. Cam duration, which M1? Etc...
Hi, and welcome from California!
Otter said HI,so do I....
I have done low compression 360's professional tuned... ran 13.60'@102..67 Cuda 3:55 's,Road Runner converter. Tune,what you have.
The cam is a 440 intake and 440 exhaust but i have no clue about the duration, the second motor was a dirt track motor and they was limited to duration and lift so i would say less than 280/280 duration
