milling heads
ibleedmoparts
Milton, Fl
how much would i need to mill the heads on a 8.4:1 360 to reach 9:1 safely? Its a 77' smoger. Any help is appreciated
what head gaskets are you planing to use ........and what pistons are they....there is a ration on volume get the formula it will be self expanitory...also possible thought change pistons to higher comperssion..might be easier perminat fix
was looking at a kit from summit with these pistons...But im unsure of stock head cc...just considering this, any help would be great so i don't make a disastrous mistake
Brand: Speed Pro
Product Line: Speed-Pro Hypereutectic Pistons
Part Type: Pistons
Part Number: STL-H405CP
Bore (in): 4.000 in.
Bore (mm): 101.600mm
Piston Style: Flat top, with four valve reliefs
Piston Material: Hypereutectic aluminum
Compression Distance (in): 1.637 in.
Piston Head Volume (cc): +10.00cc
Wrist Pin Style: Press-fit
Pin Diameter (in): 0.984 in.
Piston Ring Thickness: 5/64 in. x 5/64 in. x 3/16 in.
Quantity: Sold individually.
Notes: DurOshield® coated piston skirt.
Piston, Hypereutectic, Flat, 4.000 in. Bore, 5/64 in., 5/64 in., 3/16 in. Ring, Chrysler, 360, Each
Not to high jack this thread, but I have the same question.
I have stock pistons and I'm wondering how far I can go before bad things happen!
Whats the height from crankshaft centerline to the block deck? Heads are probably 72-73 cc's.
